Speed and Dig input opinions.. HELP!
Hi guys,
I'm just wondering if I can get all these 3 inputs onto the SDL?
We only have 2 Speed inputs and 2 dig inputs. I plan to use wheel speed 1 on a front wheel (wheel speed), and wheel speed 2 on the Tailshaft.
I then have a pulley which I plan to use for picking up RPM.
It is a GT101 sensor reading a pulley off the crank. The only thing is that it is an alloy pulley with holes drilled into it, which were tapped and then 2 magnet screwed in which were then shaved flush. The GT101 sensor is a hall effect sensor. The sensor has 3 wires - 8v, gnd and sensor.
Anyway, my plan is to run the tailshaft and wheelspeed on the speed inputs. Can I use the dig input with the pulley for RPM?
Btw, its a carby motor.
Baz
Baz
