Exhaust Back Pressure Sensor - Compatibility
Postby bazeng on Wed Nov 11, 2009 1:11 am
Hi guys,
Will this be compatible with the SDL?
http://www.aempower.com/ViewProduct.aspx?ProductID=1437
http://www.aempower.com/ViewProduct.aspx?ProductID=1438
http://www.envyperformance.com/index.cf ... ct_ID=2280
I'm looking for some sensors to monitor back pressure prior to the turbo.
Does motec offer anything of the sort?
bazeng
Re: Exhaust Back Pressure Sensor - Compatibility
Postby JamieA on Wed Nov 11, 2009 12:45 pm
I would expect that we could read those sensors into an ECU or a dash without any problems, but we don't stock an exhaust back pressure sensor specifically.
the links that you provided don't really show any calibration information, but looking at them, I would guess a .5 - 4.5v sensor range, which we could use no problems.
regards
Jamie
JamieA
Postby JamieA on Wed Nov 11, 2009 4:00 pm
After more discussion...
you couldnt run that sensor directly into the exhaust, I suspect at 800deg, the sensor would melt the plastic end off it, and the electronics would fail. So assuming it is just another pressure sensor, then you should just use a normal delco pressure sensor, and a coil of bundy tubing to get the temperature out of the gas before it gets to the sensor...
I have looked into a few other exhaust pressure sensors (Kelvico for example) and they have a max temp of 125c, so again, they would need to be mounted far away from the exhaust itself also, so no advantage to them over any of the other pressure sensor options either...
-Jamie
JamieA
Postby IDP on Wed Nov 11, 2009 11:08 pm
IDP
Postby bazeng on Tue Nov 17, 2009 9:17 am
Jamie,
Do you know a supplier? or do you supply these?
I would like 2.
Thanks for the link IDP, I looked into those and depending if I can get some locally, I'll get them from those guys.
They too will also require a cooling coil in order to work.
They quoted about $370USD for 2 sensors without the coil shipped to AUS.
bazeng
Postby JamieA on Tue Nov 17, 2009 11:09 am
I would just recommend running a delco map sensor on the end of a coil of tube. They are relatively inexpensive, and easy to source.
JamieA
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 34 guests
