SDL Nag message
Fri Nov 06, 2009 6:43 am
by IJ.
I don't have logging enabled in my SDL and get the "logging not installed" message each time I transfer a file to it, is there a way to get rid of this?
Re: SDL Nag message
Fri Nov 06, 2009 2:14 pm
by Martin
Turn off all the logging in your config.
It asks because there are some channels set up to log in your config allthough you done have logging.
Re: SDL Nag message
Fri Nov 06, 2009 6:04 pm
by IJ.
Thanks for the suggestion Martin, the only "logging" in my config is "Device Up Time" and this is a default that can't be turned off. (if you try it just renables itself at the next file load)
I had hoped someone at MoTeC would have addressed this issue by now as it's annoying to put it mildly...
Re: SDL Nag message
Sat Nov 07, 2009 4:56 am
by Martin
I see what you mean.....
Get the 8Mb Logging upgrade
Re: SDL Nag message
Sat Nov 07, 2009 6:01 am
by IJ.
LOL another $1400 AUD to stop the nag??
Re: SDL Nag message
Mon Nov 09, 2009 5:52 pm
by Martin
Very creative way to get you to spend 1400AUD!
Re: SDL Nag message
Mon Nov 09, 2009 6:19 pm
by IJ.
Martin wrote:Very creative way to get you to spend 1400AUD!
It's a cunning plan for sure but one that will fail
I'll keep pressing the "ok" button it's cheaper!
Re: SDL Nag message
Thu Nov 12, 2009 8:24 am
by JamieA
That is actually a bug (not intended functionality)
We have changed the logging setup to always log device up time, as it helps us determine problems with logging if they happen. A side effect of this seems to be that it gets put into the logging list even if you don't have logging, which it shouldn't.
Ill get it fixed in an upcoming version..
regards
jamie
Re: SDL Nag message
Thu Nov 12, 2009 11:57 am
by IJ.
Thanks Jamie,
You're back on the Christmas card list
