SDL Nag message
Discussion and support for current Advanced Dash Loggers, Sport Dash Loggers and Club dash loggers
SDL Nag message
Postby IJ. on Fri Nov 06, 2009 6:43 am
I don't have logging enabled in my SDL and get the "logging not installed" message each time I transfer a file to it, is there a way to get rid of this?
IJ.
Re: SDL Nag message
Postby Martin on Fri Nov 06, 2009 2:14 pm
Turn off all the logging in your config.
It asks because there are some channels set up to log in your config allthough you done have logging.
Re: SDL Nag message
Postby IJ. on Fri Nov 06, 2009 6:04 pm
Thanks for the suggestion Martin, the only "logging" in my config is "Device Up Time" and this is a default that can't be turned off. (if you try it just renables itself at the next file load)
I had hoped someone at MoTeC would have addressed this issue by now as it's annoying to put it mildly...
IJ.
Re: SDL Nag message
Postby Martin on Sat Nov 07, 2009 4:56 am
I see what you mean.....
Get the 8Mb Logging upgrade :)
Re: SDL Nag message
Postby IJ. on Sat Nov 07, 2009 6:01 am
LOL another $1400 AUD to stop the nag?? ;)
IJ.
Re: SDL Nag message
Postby Martin on Mon Nov 09, 2009 5:52 pm
Very creative way to get you to spend 1400AUD! :)
Re: SDL Nag message
Postby IJ. on Mon Nov 09, 2009 6:19 pm
Martin wrote:Very creative way to get you to spend 1400AUD! :)
It's a cunning plan for sure but one that will fail :D
I'll keep pressing the "ok" button it's cheaper!
IJ.
Re: SDL Nag message
Postby JamieA on Thu Nov 12, 2009 8:24 am
That is actually a bug (not intended functionality)
We have changed the logging setup to always log device up time, as it helps us determine problems with logging if they happen. A side effect of this seems to be that it gets put into the logging list even if you don't have logging, which it shouldn't.
Ill get it fixed in an upcoming version..
regards
jamie
JamieA
Re: SDL Nag message
Postby IJ. on Thu Nov 12, 2009 11:57 am
Thanks Jamie,
You're back on the Christmas card list ;)
IJ.
Return to ADL3, SDL3 and CDL3
Users browsing this forum: Google [Bot] and 16 guests
