ADL3 Maths process time
Wed Oct 28, 2009 9:55 pm
by richib2002
Hi, I am working on a project at the moment using and ADL3 to control semi active dampers. I can input the algorithums into the maths channels ok but I have just noticed that the maths only re-calculate 50 times a second. I require the calculations at around 500 times a second, can the clock be wound up at all?
Re: ADL3 Maths process time
Fri Dec 04, 2009 2:18 pm
by DarrenR
Yes the Advanced maths is only calculated at 50Hz, which is usually more than enough for live calculations. There is a request is to speed it up to 100Hz but it will not go any higher than that, and changing this will cause problems with existing installations so may not be changed.
Doing advanced control is not the primary function of the ADL3 unfortunately.
Can i ask what is required to control the semi active dampers??
