RPM Input to ADL from Honda CBR Ignition Module
Posted: Tue Oct 27, 2009 7:20 pm
Hi all,
Even though this is a question about an older ADL, I beleive it is relevent for the ADL2/3 and other ignition system combinations as well.
I am using the logger/display on a 1989 Honda CBR 600 engined vehicle. The only RPM output the standard ECU has is the low side driver for one of the two coil packs (wasted spark). This was originally used to trigger the standard Honda Tacho, but I was wandering if it is safe to use it as an RPM input on one of the ADL digital inputs (considering back EMFs and the like).
Does anyone have any ideas?
*Latest*
I have just had a play around with an occilliscope during cranking and my proposed input (coil negative side drive) is seeing back EMF voltages of 200v upwards, as the coil is switching on and off. Is this safe to use?
*Latest*
