SDL Power Supply
Would it be possible to run an SDL from the download connector (0v, 8v, Can Hi, Can Lo) as a separate logger in a race car? The reason im asking is id like to plug a SDL into the downlaod connector of cars (racing in the same class running Mx00 ECU`s) to be able to do spot checks on certain engine parameters and log them to varify that they are within the rules.
The logging kit will be a backlit SDL and BL1 Gps all installed into a box that will be added into the car without modifying or adding any wiring. Would the ECU 8v supply enough current for the SDL and GPS to stay alive?
