Sport Dash Manager digital input config
I have found a problem using Sport Dash Manager 1.60.80.0 -- we have the CAN communication configured for a BR2, but we also have a digital input that we want to use for the beacon source -- I disabled the beacon channel on the BR2, and use the Calculations->Lap Time and Number dialog to select "Beacon Type" as BRX, but after clicking OK to the dialog, the next time I open Calculations->Lap Timing and Number, it has been reset to BR2 (on CAN).
I have confirmed that I don't have this problem with either ADL2 Dash Manager, or older Dash Manager -- just with Sport Dash Manager.
Is this OK, -- will I still be using the digital input for the "Beacon" channel, even if Beacon Type is set to BR2 (on CAN).
I like keeping the BR2 setup, since I can use its diagnostics to set beacons manually if my primary beacon source fails to trigger.
