E888 SDL M800
Fri Jul 31, 2009 3:37 pm
by killerbee
When looking at the channels passed from the E888 to the SDL via CAN I see reference to "exhaust temp # (obselete)" I this normal and if not what am I doing wrong ?
Thank You
Re: E888 SDL M800
Mon Aug 03, 2009 10:35 am
by Ben-S
Normal, it says that because it's a lower sample rate I think.
Re: E888 SDL M800
Fri Aug 07, 2009 2:43 pm
by RossB
These channels come up as Obsolete because there was a change made to the Master Channel list. The channels will work ok and you can re-name them in the Channel Editor if you want to .
Re: E888 SDL M800
Sat Aug 08, 2009 9:22 am
by IJ.
Never been able to get EGT's to display on the SDL using the exhaust temp channel any suggestions Ross?
Re: E888 SDL M800
Fri Aug 14, 2009 11:57 am
by JamieA
it should just work by selecting the correct channel name. Perhaps post your config to let me have a look...
-Jamie
Re: E888 SDL M800
Fri Aug 14, 2009 5:24 pm
by IJ.
Steve T has copies of all my files Jamie, I'm in the middle of a total revamp so it's not really important now but I will post again once the car is running.
