E888 SDL M800
Discussion and support for current Advanced Dash Loggers, Sport Dash Loggers and Club dash loggers
E888 SDL M800
Postby killerbee on Fri Jul 31, 2009 3:37 pm
When looking at the channels passed from the E888 to the SDL via CAN I see reference to "exhaust temp # (obselete)" I this normal and if not what am I doing wrong ?
Thank You
killerbee
Re: E888 SDL M800
Postby Ben-S on Mon Aug 03, 2009 10:35 am
Normal, it says that because it's a lower sample rate I think.
Ben-S
Re: E888 SDL M800
Postby RossB on Fri Aug 07, 2009 2:43 pm
These channels come up as Obsolete because there was a change made to the Master Channel list. The channels will work ok and you can re-name them in the Channel Editor if you want to .
Re: E888 SDL M800
Postby IJ. on Sat Aug 08, 2009 9:22 am
Never been able to get EGT's to display on the SDL using the exhaust temp channel any suggestions Ross?
IJ.
Re: E888 SDL M800
Postby JamieA on Fri Aug 14, 2009 11:57 am
it should just work by selecting the correct channel name. Perhaps post your config to let me have a look...
-Jamie
JamieA
Re: E888 SDL M800
Postby IJ. on Fri Aug 14, 2009 5:24 pm
Steve T has copies of all my files Jamie, I'm in the middle of a total revamp so it's not really important now but I will post again once the car is running.
IJ.
Return to ADL3, SDL3 and CDL3
