ADL3 counters
I'm considering using an ADL3 dash, and have been looking at the configuration software.
One thing I want to do eventually is a custom paddle shift setup for what is essentially an H pattern gearbox.
The mechanical / pneumatic side of it all looks doable, and my initial plan was to use the PDM to control everything.
The control solenoids are only very small though so it's a bit overkill using 8amp PDM outputs to drive them.
Looking at the ADL3 settings, there are channels for counters and counter up/down inputs, but I can't find the function.
Searching counters in the help finds a page on setting them up, but it's not in the help index or in the config software as far as I can tell.
Am I missing something, or is there no general purpose counter function?
I found a forum post about doing a counter setup on an ADL2 so I can probably use that method, but it would be nicer to use a built in function if possible.
thanks
thanks
