ADL3 counters
ADL3 counters
Postby SXD on Mon May 24, 2021 11:08 pm
I'm considering using an ADL3 dash, and have been looking at the configuration software.
One thing I want to do eventually is a custom paddle shift setup for what is essentially an H pattern gearbox.
The mechanical / pneumatic side of it all looks doable, and my initial plan was to use the PDM to control everything.
The control solenoids are only very small though so it's a bit overkill using 8amp PDM outputs to drive them.
Looking at the ADL3 settings, there are channels for counters and counter up/down inputs, but I can't find the function.
Searching counters in the help finds a page on setting them up, but it's not in the help index or in the config software as far as I can tell.
Am I missing something, or is there no general purpose counter function?
I found a forum post about doing a counter setup on an ADL2 so I can probably use that method, but it would be nicer to use a built in function if possible.
thanks
SXD
Re: ADL3 counters
Postby David Ferguson on Tue May 25, 2021 5:32 am
Please describe what you think a "general purpose counter function" does. I bet the counters can be used for this, but I'm not understanding what you are looking for.
Re: ADL3 counters
Postby SXD on Tue May 25, 2021 9:44 am
I want to be able to increment a counter up and down based on switch inputs, with max / min values in either direction - the same as the counter function in the PDM or later dashes.
As far as I can tell, there is no counter function available on the ADL3.
Obviously it has a lap counter, page up/down counter etc, but I want to set up a custom one.
SXD
Re: ADL3 counters
Postby David Ferguson on Tue May 25, 2021 10:00 am
You're right. Counter functionality (Calculations->Up/Down Counters...) came with the Cxxx Dashes, I was thinking the ADL3 and CDL3 had those as well, but they don't. Sorry.
Re: ADL3 counters
Postby SXD on Tue May 25, 2021 10:17 am
bummer!
I was a bit confused by the counter function being in the help but not actually available!
It should be doable with the maths / table functions.
Otherwise I might have to save some more cash and get a C125 (although then it doesn't have enough IO for what I'm doing...)
SXD
Re: ADL3 counters
Postby David Ferguson on Tue May 25, 2021 10:44 am
The replacement for a ADL3 is a C185/C187. You can even use the same harness.
Re: ADL3 counters
Postby SXD on Tue May 25, 2021 11:48 am
Unfortunately the C185 is well out of my budget!
SXD
Re: ADL3 counters
Postby Stephen Dean on Tue May 25, 2021 12:04 pm
Having built a Paddle Shift system using a PDM as the control system (had to retain the factory ECU) I wouldn't do it. The timings in the PDM for the switching are not fast enough to properly do the shifts.
Re: ADL3 counters
Postby SXD on Tue May 25, 2021 8:01 pm
my gearbox is probably also a lot slower than the average paddle shifted setup, but that's good to know!
This is a bit of a future experiment (I'm currently running an external mechanical sequential shifter) so I'll build and test the hardware on the bench first either way.
I was originally planning on building my own controller which would handle the shifting and output a gear position signal (either CAN or analog / PWM) but the counter function in the PDM got me thinking about doing it that way and saving myself some work.
SXD
Re: ADL3 counters
Postby Auto Sport Elect on Tue May 25, 2021 11:33 pm
I have previously used counters on an SDL, so an ADL3 should do it easy.
Use Darren's method described in this post viewtopic.php?f=14&t=162
Auto Sport Elect
Return to ADL3, SDL3 and CDL3
