CDL3 RS232 serial OUTPUT
Postby greenamex2 on Wed Nov 25, 2020 9:29 am
Hi all
I expect I am about to be very upset but...
Is there any way to OUTPUT a RS232 serial stream from a CDL3?
Was hoping to pick up a stream of some kind into the PC in the car for a Python driven gauges display without duplicating the UTC already attached to it with an after market USB to CAN device (ran out of USB ports).
Thanks in advance
greenamex2
Re: CDL3 RS232 serial OUTPUT
Postby David Ferguson on Wed Nov 25, 2020 9:59 am
Try Selecting Telemetry Only, then edit the template and change Device to Async TX 1. Modify the ASCII Transmit Setting to add a delimiter and termination. Add some channels and see what you get.
If you're planning to use serial GPS, you'll need to put that on another RS-232 RX
Good Luck.
Postby greenamex2 on Wed Nov 25, 2020 6:51 pm
Looks very promising, thanks David.
Will test further when 15 dollar serial cable arrives!
greenamex2
Return to ADL3, SDL3 and CDL3
