Sports dash M1 can template
Fri Aug 07, 2020 7:53 pm
by Donovan CR6
Hi
Is it possible to get a M1 template for a sport dash? Currently trying to connect to a M142. Cant even manually input it.
Re: Sports dash M1 can template
Wed Aug 12, 2020 9:52 am
by adrian
See below, you need to unzip the file and copy the templates to C:\Program Files (x86)\MoTeC\Dash\Sport Dash Manager 1.6\Comms Setup. You will then be able to select them in the communications setup in SDL Manager.
Wed Aug 12, 2020 6:26 pm
by Donovan CR6
Hi Adrian
When trying to load the config I get this error just after it finishes loading.
Any Ideas?
Wed Aug 19, 2020 3:03 pm
by adrian
Can you send me the Dash configuration file that does this to
support@motec.com.au
