Brake Pressue Bias Channels CDL3
Hi All,
I have a M130 and have run out of AV inputs for brake pressure. I want to be able to run front and rear brake pressure sensors from a pedal box, and display on the dash the F/R balance a a percentage.
I have been able to set up the channels individually, but can't seem to find a way to create a channel to show the balance as a percentage. I know the maths require is below, is this a limitation of the CDL, and is there another way to create it if so.
ie Bias = (Front Pressure / (Front Pressure + Rear Pressure)) * 100
Cheers
Simon
Cheers
Simon
