SDL display, making alarms take priority above overrides.
Tue Nov 20, 2018 8:55 am
by Sean
Greetings, got a SDL here as a display for an ACL. From my understanding alarms are supposed to take priority over everything else on the bottom line of the display, however in this case the alarm message doen't take priority over the bottom line when an override (such as pit limiter active status) is active. Anyone have any thoughts on this? Thanks.
Re: SDL display, making alarms take priority above overrides
Tue Nov 20, 2018 10:07 am
by David Ferguson
turn your bottom line overrides into alarms, then you can set the priority.
Tue Nov 20, 2018 11:21 am
by Sean
David Ferguson wrote:turn your bottom line overrides into alarms, then you can set the priority.
Thanks David, makes a lot of sense.
