SDL display, making alarms take priority above overrides.
Postby Sean on Tue Nov 20, 2018 8:55 am
Greetings, got a SDL here as a display for an ACL. From my understanding alarms are supposed to take priority over everything else on the bottom line of the display, however in this case the alarm message doen't take priority over the bottom line when an override (such as pit limiter active status) is active. Anyone have any thoughts on this? Thanks.
Sean
Re: SDL display, making alarms take priority above overrides
Postby David Ferguson on Tue Nov 20, 2018 10:07 am
turn your bottom line overrides into alarms, then you can set the priority.
Postby Sean on Tue Nov 20, 2018 11:21 am
David Ferguson wrote:turn your bottom line overrides into alarms, then you can set the priority.
Thanks David, makes a lot of sense.
Sean
Return to ADL3, SDL3 and CDL3
