M880 - CDL3 Custom Dataset settings
Hi All,
I have a M880 configured and working with a CDL3 for the base CAN communications and am now trying to get some extra data over from the M880 to the CDL3 via Custom Dataset 2.
Current settings for the M880 - CDL3 base dataset are as follows:
M880
Can 0 Data = 1
Can 0 Address = 1520
Can 0 Transfer Rate = 50
CDL3
Device = Async Expander
Format = Fixed Binary
Alignment = Normal
Receive Timeout = 2200
Address Format = Standard
Async Device = M8
Base Address = 5F0
What settings do I need to use on the M880 and CDL3 to get the extra data in Custom Dataset 2 over to the CDL3? I have created a comms template, exported it from the M880 and imported it on the CDL3 but am not sure what to use for the rest of the settings. I will be using Can Data 1 on the M880 side. If I simply load the template, it defaults to channel 5F0 which causes DashManager to throw an error saying that the address is already in use. If I change the address on both the M880 and CDL (I used 233 as I dont have any MDD in the system) it doesnt seem to change anything and I get a 512 Comms Can diag channel on the CDL
M880
Can 0 Data = 1
CDL3
Alignment = Normal
Async Device = M8
Base Address = 5F0
