CDL3, GPS and RS232
CDL3, GPS and RS232
Postby bdinnerv on Mon Jul 09, 2018 5:49 pm
Hi All,
Is there any reason why the GPS-L10 is wired into the CAN bus on the CDL3 Track w/ Logging loom and not into the RS232 pins? Is there a difference between RS232 on CAN vs RS232? If not, can I simply re-pin the connector to route the GPS to the dedicated RS232 pins and free up the second CAN bus?
Cheers,
Ben
Its not the speed that kills, its the sudden stop at the end
bdinnerv
Re: CDL3, GPS and RS232
Postby Stephen Dean on Mon Jul 09, 2018 6:20 pm
Hi Ben,
You can change the GPS input to the RS-232 pin and then setup the GPS template in that section.
Return to ADL3, SDL3 and CDL3
