cdl3 crashing on warmup tab
Postby Entranced on Wed Jul 04, 2018 11:53 am
Downloaded my calibration I got from my tuner off the dash and started looking at the screens and I get "unit type not found" message (see attached) and the program crashes.
I contacted my tuner and sent him the calibration file and it opens normally on two of his computers without issue.
Any ideas? Thanks!
Fault screen capture
Entranced
Re: cdl3 crashing on warmup tab
Postby adrian on Wed Jul 04, 2018 1:17 pm
Can you please try copying the below file to C:\Program Files (x86)\MoTeC\Common\1.0\Units\en and see if that fixes the problem.
Couple of things to note:
Make sure you close Dash Manager before you copy the file.
If you are asked to override the existing file, click yes.
units.xml
(52.5 KiB) Downloaded 1195 times
Postby Entranced on Wed Jul 04, 2018 1:39 pm
replaced the units file with the one you attached but it didn't resolve the fatal error. still crashes only on warmup tab.
Entranced
Postby adrian on Wed Jul 04, 2018 2:16 pm
Ok, can you please send your config file to support@motec.com.au and I'll take a look at it.
Return to ADL3, SDL3 and CDL3
