CDL3 speed to M800
PostPosted: Sat Oct 08, 2016 1:10 am
by cotje
I have a nice working combination of M800 connected to a CDL3. Is it possible to transmit the CDL3-GPS-Speed data to the M800 as inputchannel and use it as groundspeed indicator for Launch Control?
I tried configuring a CAN channel to receive ADL data, but to no reveal.
Anyone a solution?
Re: CDL3 speed to M800
PostPosted: Sat Oct 08, 2016 7:59 pm
by Sean
Assuming you are already receiving data from the ECU successfully, something like this should be close. Open the can setup in CDL manager , set to the following. Hex address 0F3 is 243 in decimal which we use in the ecu.
Connections/communications/ Set up a new template on the can bus the ecu is connected to..
Select the channel to transmit
PostPosted: Sat Oct 08, 2016 8:07 pm
by Sean
General setup/comms/can setup The 243 number is the can address in decimal
Sensor setup/input setup/speed
That's more or less it, you may have to mess with the addressing a bit.
On a separate point, an actual ground speed from a wheel would be better than gps speed for launch control, if you have it. Actual ground and drive speed sent directly in to the ecu is better still.
PostPosted: Sun Oct 09, 2016 3:53 am
by Scott@FP
Sean with an AWD GPS speed works better for LC since there is really no true ground speed reference during AWD wheelspin.
PostPosted: Sun Oct 09, 2016 12:33 pm
by Sean
Scott@FP wrote:Sean with an AWD GPS speed works better for LC since there is really no true ground speed reference during AWD wheelspin.
That makes perfect sense Scott.... I'm a dinosaur, only work on 2wd stuff so I live in jurassic world :roll:
PostPosted: Sun Oct 09, 2016 7:00 pm
by cotje
Thanks guys! Great info.
I entered these setting but there is still no speed metric available in the M800. I also tried another address setting but this did not help either. I must be missing a small detail.
Will send the pictures from my current setting soon.
PostPosted: Sun Oct 09, 2016 7:23 pm
by Sean
There is a MoTeC tech note DTN0005 ADL data to M800 via CAN comms, I'll see if I have the .pdf around, as far as I know ADL, SDL, CDL all use the same method.
Edit: Found it.... This is the latest version I had.
DTN0005_ADL_data_to_M800_via_CAN_comms[1].pdf
(126.41 KiB) Downloaded 1968 times
PostPosted: Mon Oct 10, 2016 2:45 am
by cotje
Perfect Sean! The instruction in de doc made it work. Happy Motec user here :D
