GPS antenna location
Fri Jan 01, 2016 1:59 pm
by DJDINO
About to mount the GPS antenna in the race car and assume the centre of the roof is the ideal location ? I was going to drill a hole in the centre of the roof and run the wire through a grommet. Is the centre of the roof (centre of car front to back) ideal ?
Re: GPS antenna location
Fri Jan 01, 2016 11:07 pm
by greenamex2
What material is the roof made out off?
Sat Jan 02, 2016 11:51 pm
by DJDINO
Roof is steel
Sun Jan 03, 2016 12:48 am
by greenamex2
As long as it is more the 10cm from the edge, stick it wherever is convenient.
Wed Apr 20, 2016 5:23 pm
by FoxSTI
greenamex2 wrote:As long as it is more the 10cm from the edge, stick it wherever is convenient.
May I ask why the 10cm setback from a rood edge?
Wed Apr 20, 2016 6:08 pm
It is to ensure a good area for the ground plane of the antenna, this increases the efficiency of the antenna.
Thu Apr 21, 2016 1:11 am
by FoxSTI
Thanks.
would this be a good place to ask the different between the two GPS flavors offered by MoteC?
