c125 / m800 CAN help
PostPosted: Sun Jul 12, 2015 4:04 am
by fordpop
Im struggling to get the CAN settings on the above set up.
I've just swapped from the M84 to the M800. The dash & M84 were working just great but I cant get any comms with the M800.
The dash/logger CAN address was 232. In the dash, M84 was on CAN2 with the base address of 0E8.
So, I set up the M800:
CAN 2 Data: 4
CAN 2 address: 232
Clearly this is not correct - any ideas, pointed or a working can file for each??
Re: c125 / m800 CAN help
PostPosted: Sun Jul 12, 2015 12:31 pm
by Sean
In the ECU CAN2 is a CAN template rather than a separate CAN bus, M800 has one CAN bus only. To transmit data to the dash it should be sent on CAN 0. Assuming you have the ECU wired to CAN2 on the dash since it worked with the M84.......
Try this in ECU manager
And this in C125 manager
PostPosted: Sun Jul 12, 2015 5:28 pm
by fordpop
thanks Sean - got it sussed:)
I used the 1520 address on CAN0 in the ecu manager & the template in the dash & we have comms.
Thanks again.
