Lambda/SDL
Discussion and support for current Advanced Dash Loggers, Sport Dash Loggers and Club dash loggers
Lambda/SDL
Postby nick on Sun Dec 14, 2008 9:02 am
Whats the best Lambda probe to use with the SDL?
nick
Re: Lambda/SDL
Postby NathanS on Wed Dec 17, 2008 2:20 am
If you're looking to connect the lambda probe directly to the SDL then you can only use the Bosch LSM 4 wire sensor, there is a drawing for this sensor on the datasheets download page, you will also need lambda measurement enabled in the SDL that you are using.
NathanS
Re: Lambda/SDL
Postby gring on Fri Dec 19, 2008 3:09 am
You should be able to use the Lambda to CAN modules with the Bosch LSU 4.9 sensor with the SDL, right?
gring
Re: Lambda/SDL
Postby AlanB on Fri Dec 19, 2008 3:46 am
Yes that is correct, LTC modules will be compatible with existing products.
AlanB
Return to ADL3, SDL3 and CDL3
