CAN Pin71,72
CAN Pin71,72
Postby TEDean on Sun Jan 25, 2015 4:44 am
Can you use P71 and 72 to interface into the CAN loop like P74 and P73?
I am trying to add TPMS onto the CAN loop.
TEDean
Re: CAN Pin71,72
Postby David Ferguson on Mon Jan 26, 2015 9:06 am
Which ADL model to you have? On the original ADL and the ADL2, there is only one CAN bus, and the second set of pins are internally connected to the same bus. On the ADL3 & C185 there is more than one CAN bus, and each one will need termination, and you have to correctly configure which CAN bus your device is connected.
Return to ADL3, SDL3 and CDL3
