Running 5 minute average calculation
Postby JulianEdgar on Sun Oct 26, 2014 9:39 am
I have an ADL3 dash and M400 running a 3 cylinder Honda Insight turbo.
I'd like to be able to calculate averages for certain rolling time frames - for example, average fuel economy for last 5 minutes.
I have instantaneous fuel consumption being calculated (via adv maths functions, with calculation based on duty cycle and speed).
Can anyone tell me how to gain this 5 minute rolling average?
I am very new to the advanced maths functions, so be nice if the answer is obvious!
JulianEdgar
Re: Running 5 minute average calculation
Postby JulianEdgar on Mon Oct 27, 2014 4:18 pm
OK easiest way proved to be in channel maths - just use a filter (with a constant of 5000) on the instantaneous fuel consumption channel. That gives a rolling average of about 5 minutes - I just trialled different constants until it seemed about right.
However, I have another issue.
I am using two expressions in the ADL3 advanced maths:
('Fuel Inj Duty'[ratio]*0.643*60)/('GPS Speed'[km/h])*100
- with the output channel of 'Ins Fuel Econ'
This gives me instantaneous fuel economy in litres/100km and works well. However, to avoid it showing silly stuff when the car is stopped (and wrecking averages like the 5 minute filter described above), I have added:
choose('Drive Speed Left'>1,'Inst Fuel Econ',0)
- which returns a value of 0 for Inst Fuel Econ when speed is les than 1 km/h. It uses channel output User Math 1.
The problem is that User Math 1 then has no decimal places - just whole units. I need at least one decimal place (and preferably two) in this output channel.
How do I get back my missing decimal places? I have tried adding the units, multiplying by 100 at an earlier stage and then subsequently dividing - nothing seems to work.
JulianEdgar
Postby JulianEdgar on Tue Oct 28, 2014 9:55 am
OK, fixed this problem.
Incredibly, it seems as soon as you select a 'user maths' channel, resolution immediately drops to whole digits.
I got around it by selecting higher resolution unused channels (eg aero pressure 1, aero pressure 2) to do the calculations and then display those under changed names.
JulianEdgar
Postby AdamW on Thu Oct 30, 2014 7:28 pm
I think your problem is that the user math channels are not for normal use in an ADL, it seems you have selected a channel that belongs to the Interpreter category:
You should instead choose one of the general purpose channels from the top of the category list (not shown in this pic).
Motorsport Electronics Ltd.
AdamW
Postby JulianEdgar on Fri Oct 31, 2014 8:13 pm
Thank you - I hadn't realised channel selection was so important, Now I do!
JulianEdgar
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 45 guests
