Gear Detection Sensor Algorithm?
When using an ADL3 and Gear Detection set to the Sensor method -- How exactly is the gear detection done? Are the values entered into the Sensor Value table used as the "center points" for a particular gear? Or are they more of a threshold?
For example, let's say the sensor gear voltages were as follows:
Gear 1 - 1.5V
Gear 0 - 2.0V
Gear 2 - 2.5V
Gear 3 - 3.5V
Gear 4 - 4.5V
What would be the voltage range that would map to Gear 1? Gear 2? Other gears?
Thanks for any insight.
Gear 1 - 1.5V
Gear 0 - 2.0V
Gear 2 - 2.5V
Gear 3 - 3.5V
Gear 4 - 4.5V
