CDL3 - Evo X - Reading boost.
Hello.
I have the CDL3 Track logging kit installed on my Evo X.
I have had it for awhile and love it. However I have never been able to get it to read boost correctly.
Whether I select, PSI, PSIg, PSIa, Bar, etc, i get a positive reading at idle.
Under throttle the number reduces to zero as boost builds and then reads really high (seen it read 33+psi when I know I should only be making 24-26psi MAX) at higher RPM's.
I am an amature at setting up this dash. Is there something I can do in the 2d or 3d tables to fix this and get it to read boost correctly. (Just guessing here as i dont really know what tables actually do).
Any help, advice or guidance would be great.
