Oil temp (from M84 (AT3) not visible in CDL3
Thu Mar 28, 2013 5:49 am
by LOLA-Christian
Hi, we have not been able to display engine oil temperature (connected to pin B5 (AT3) on M84) on CDL3.
Other temp and press are visible, but not that one.....
Any suggestions?
Re: Oil temp (from M84 (AT3) not visible in CDL3
Fri Mar 29, 2013 9:36 pm
by Martin
there is a problem in the CAN template for the M84 in the CDL3. Ive fixed mine myself, maybe its fixed in the latest CDL3 V1.4. Install latest and see. The issue is the offset of the CAN message is incorrect, you can edit it if you want. If you dont manage, try this one, maybe it will fix your problem
