Oil temp (from M84 (AT3) not visible in CDL3
Postby LOLA-Christian on Thu Mar 28, 2013 5:49 am
Hi, we have not been able to display engine oil temperature (connected to pin B5 (AT3) on M84) on CDL3.
Other temp and press are visible, but not that one.....
Any suggestions?
LOLA-Christian
Re: Oil temp (from M84 (AT3) not visible in CDL3
Postby Martin on Fri Mar 29, 2013 9:36 pm
there is a problem in the CAN template for the M84 in the CDL3. Ive fixed mine myself, maybe its fixed in the latest CDL3 V1.4. Install latest and see. The issue is the offset of the CAN message is incorrect, you can edit it if you want. If you dont manage, try this one, maybe it will fix your problem
MoTeC M84 MR.CC7
(8.12 KiB) Downloaded 1079 times
Return to ADL3, SDL3 and CDL3
