ECU to ADL Hi Speed CAN Data
Using the standard M800 to ADL data set an update rate of the around 50Hz can be expected at the ADL.
However by using the M800 custom data sets the ECU can transmit at a rate of 200Hz ( Actually nearer an average of 166Hz as measured using CANalyzer ).
However over a year ago there was a change to Dash Manager that stopped inappropriate logging rates being selected for certain channels, this is usful in the main...
However all of the engine related channels (within Later versions of DM ) are restricted to a maximum logging rate of 100Hz. So I cannont select a higher logging rate and take advantage of the higher rate at which my specified ECU channels are being transmitted. Is there a work around or future change to enable this?
Cheers, John.
Cheers, John.
