OEM Speed Sensors - Magnetoresistve
Hi all,
Have you come across 'active wheel speed sensors'. They are becoming quite common on many road cars over in europe and it would be nice to be able to use these sensors, since fitment of alternative sensors in the hubs is problematic.
Sensor Overview
Many are based on a magneto-resistive element. (some are hall apparently) The trigger wheel is a disk of material with alternately magnetically polarised segments(N/S/N/S/N... ), this disk if often a rubber/plastic material containing magnetisable particles.
The sensors is a two wire sensor and is supplied with 5-15v and Sensor 0V. (note the lack of a separate signal wire) The sensor detects the pulsing fields of the trigger disk and outputs a signal voltage, the amplitude is independent of the wheel speed. The internal amplifer/conditioner circuit inside the sensor housing converts this signal to a current pulse with a varying frequency proportional to the wheel speed, this signal is then impressed onto the supply lines ( the sensor 0v side ??).
The receiving ECU/Logger must have to monitor these supply lines, detect the current pulse and convert the frequency into a speed signal...
We are seeing this type of sensor being mounted in many different wheel hubs, I have personally seen it in Mercedes and GM cars. I guess loads of people have seen these before..... is it somthing that will be useable by current/future motec products... ADLx
Sensor Overview
