Hi
I am trying to troubleshoot a new SLM-C (first time with the SLM-C) and was wondering what address it is listening at and what the message size and offset/byte values it is looking for (or if its a compound message etc.).
I have a brand new unit, added to a fully working canbus and dash, but my CDL3 wont light it up, tried both ends of the bus (was thinking it might be a termination issue). Have power, ground, wired as per the instructions and everything else is working fine aside from the SDL-C not lighting up. Do any lights come on at power up, because none do... the only way I can trigger it right now is from the CDL3 software (which isn't working and yes its got the correct CAN bus ID) but I can also generate a CAN message to it from an ECU, PDM or any other units (the ECU isnt a motec so there isnt a default to run the SLM-C)
I've seen the thread on how to manually drive an SLM from an ADL but not the SLM-C
thanks
