CDL3 to display actual mileage
Postby Davin on Sun Jan 29, 2012 3:31 pm
I recently purchased the CDL3 Kit and installing it to my M2R. However, I want the CDL3 to replace my whole cluster including the odometer. In the software, it only has a provision to read up to five digits and my actual milage for the odometer on the chassis is over 100k, making that six digits. Is there a way to have it more than 5 digits and is there a way to input actual milage to stay street legal?
1993 Mazda RX7 | 13B-REW | T04Z | M2R (w/ logging & lambda) | CDL3 Track Kit
Davin
Re: CDL3 to display actual mileage
Postby JamieA on Mon Jan 30, 2012 8:57 am
Good question. I hadnt looked into this!
I have just setup a test dash here, and set the odometer to 195,000kms
and... it works.
the odometer in our dash range is a 32 bit number, so it will be able to read km's far beyond the life of a car.
As for a display, if you put it on the bottom row of the display, it will show at least 6 digits. It suggests in the manager that it is only going to show 5, but I just tested it, and it shows the entire 195000 that I have set the odometer to.
If you need to set your odometer to a starting value, it will have to come back to your motec dealer to be done. This is because to make the dash legal as a vehicle display, the odometer isnt allowed to be reset by law. The Pre-Setting of odometers has to be done here.
regards,
jamie
JamieA
Return to ADL3, SDL3 and CDL3
