SDL v Tremec Gearbox
Postby Robbtwr on Fri Oct 03, 2008 12:37 am
Hi.
I have a SDL and would like to be able to log speed out of a Tremec Gearbox. The gearbox has a 2 wire speed sensor in it.. I take it that it is a mag type sensor. Not sure on how to conect to the SDL. The SDL only shows Hall type sensor
If you could help that would be good.
Thank
Robb
Robbtwr
Re: SDL v Tremec Gearbox
Postby JamieA on Fri Oct 03, 2008 9:48 am
wire one wire into the 0v, the other into speed 1 or 2
Go into input pins, then speed and select the sensor type button.
In the sensor type screen, select magnetic as the sensor type
now you have a table of voltage vs speed that you can use to set up the levels for your particular sensor.
-Jamie
JamieA
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 34 guests
