SDL3+M800+Pro Analysis?
Do I have to have Pro Analysis enabled in both SDL3 and M800 to be able to use the M800 dataflow that is logged in the SDL3?
/J
/J
The official support forum for MoTeC products
https://forum.motec.com.au/
Mr.J wrote:Do I have to have Pro Analysis enabled in both SDL3 and M800 to be able to use the M800 dataflow that is logged in the SDL3?
/J
Chris Wilson wrote:Amazingly I was going to post an almost identical question. This almost answers mine, but not quite. I was about to get Pro Logging enabled on my M800 with 1 meg logging already enabled. When funds permit I was going to get either an ADL3, an EDL3, or a used ACL and a VIM. I take it that enabling Pro Logging in the M800 will not result in logs from a *DL3 being readable in i2 Pro that's not licensed?
Chris Wilson wrote:Will data from the M800 with pro Logging enabled be readable in i2 Pro if it's fed into a *DL3 without the logger itself having Pro Logging enabled?
Chris Wilson wrote: I also believe that all ACL's have Pro Logging enabled by default, correct?
