Connect tyre temp sensors by CAN to ADL3
Postby gust0214 on Mon May 09, 2011 11:21 pm
We buy two texense sensors IRN8 (tyre temperature in 8 points) this sensors need CAN connection we have connected in CAN 1 the beacon when I use. Is possible that you give me the steps to connect this sensors and setup the CAN?
We wait your response to soon as possible
gust0214
Re: Connect tyre temp sensors by CAN to ADL3
Postby JamieA on Wed May 11, 2011 10:11 am
can you please send me the documentation on this unit, so that I can look at how we can set it up.
regards
jamie.
JamieA
Postby gust0214 on Wed May 18, 2011 12:46 am
Dear Jamie
I send you the data sheet of this sensors
thank you for your help
IRN8C2F1_fev10.pdf
(171.93 KiB) Downloaded 2165 times
gust0214
Postby gust0214 on Mon May 30, 2011 11:07 pm
Dear Jamie
any news for me
i wait your response to soon as possible
gust0214
Postby OmarK on Mon Jul 18, 2011 11:07 am
Attached is the default CAN comms template for the Texense IRN8 sensor for use in SDL3 and ADL3 via CAN. Load this into a spare CAN template in the Communications Setup. The template was made a few years ago but should still work, let us know how you go...
Texense IRN8 Default.cc7
Default CAN comms template for the Texense IRN8 sensor
(8.12 KiB) Downloaded 1724 times
OmarK
Postby mangel83 on Fri Nov 09, 2012 5:12 am
Hi Omar,
Would you happen to have the CAN comms template for the Texense IRN4 sensor for use in ADL2?
mangel83
Postby OmarK on Mon Nov 26, 2012 12:07 pm
From what I have heard from Texense, the IRN4 is the same as for IRN8 with only 1 CAN ID used for the 4 channel sensor.
OmarK
Return to ADL3, SDL3 and CDL3
