SDL3
Discussion and support for current Advanced Dash Loggers, Sport Dash Loggers and Club dash loggers
SDL3
Postby Frebo74 on Fri Mar 18, 2011 7:02 am
Hi
I have an SDL3 that I have some trouble with. I had problems connecting it to computer, but that is resolved. But when I tried to transfer data to the SDL3 from PC it worked good for half the transfer and then the back lite disapeard and at the bottom line the dash write CFG CRC ERROR. What is that??? I can not make any connection to the SDL3 now and if I take away the power and turn it back it just print the same. Is there any way to reset the dash? Can anyone please help me here...
Thank's
Frebo74
Frebo74
Re: SDL3
Postby JamieA on Tue Mar 29, 2011 4:10 pm
"CFG CRC error" means that the configuration that you are trying to send to the dash is corrupt, and cannot be sent to this dash. Reasons for this include sending an SDL file to an SDL3 without converting it, or having a file that was half saved before a laptop crash / power loss.
Try creating a blank dash configuration and sending it to the dash. That should go in.
If it does work you way back up to sending the problem config again later.
regards.
JamieA
Return to ADL3, SDL3 and CDL3
