BackLight
Discussion and support for current Advanced Dash Loggers, Sport Dash Loggers and Club dash loggers
BackLight
Postby insomnia on Mon Feb 28, 2011 5:54 pm
Hi ,
I have a SDL3 mounting on a road motorcycle. As you know a motorcycle is running with the light "on" day and night.
How can i use a toggle switch for activate the Backlight ? Or can i use a variable resistor to increase and decrease the Backlight ? It's for adjust the better contrast....
Thank you.
insomnia
Re: BackLight
Postby JamieA on Tue Mar 01, 2011 8:09 am
you can put a toggle into a Dig input, and us a GP on/off channel to recieve this input.
Once you have done this, add a 2 D table with 0 being 0%, and 1 being 80% (or the required brightness) - See picture.
backlight bright.jpg (71.51 KiB) Viewed 9716 times
The other option is to put in a dial (the MoTeC 9 position switch for example) into an AV.
you can then just calibrate the input voltage from the AV into a backlight brightness channel.
Finally go into the Display / Backllight tab, and select the user channel value button, and choose the backlight brightness channel.
regards
Jamie
JamieA
Re: BackLight
Postby insomnia on Tue Mar 01, 2011 5:44 pm
Thank you JamieA .
insomnia
Return to ADL3, SDL3 and CDL3
