SDL display next line
Hi there,
Sorry for the dumb question but,
I am trying to get the next line function to work on an SDL.
I have set up the next line in dash display/channels and in Input pins/switches.
I have set up the switch for active low.
I test the switch in test mode and i see it work, confirmed by changing from 0 to 1 when switch is pressed.
Do i need to set up a Mode Switch also for this function to operate, if so is it possible to parallel input switch 1 and 2 together (set up as input 1 mode switch,input 2 display next page) to save fitting another switch.
Would there be any issues with connecting input 1(Mode switch) permanately to 0 volts,so that the Next page button works all the time without the need for a seperate Mode buttton.
Thanks.
Thanks.
