ADL3 Internal G sensor calibration
I was working with my first ADL3, and noticed that the calibration for the internal G-sensor didn't seem quite right. My observations were based on bench top-use where after zeroing the internal G channels, I set the dash on it's side to measure +/- 1.0 g. I found that I had to set the lateral G-sensor to 125 mV/G, while the longitudinal and vertical G-sensor was best at 120 mV/G.
Lastly, this dash is mounted into the car tipped back at a 25 degree angle (so long G & vert G are offset when static). Does the dash compensate for that if I zero the long G sensor when mounted? Or should I zero it in the vertical position, then use an I2 Math Channel to generate a corrected Long G (and VertG)? something like: CorrLongG = (SensorLongG - offset) * Sine(25 deg)
The online help is unusually silent (for MoTeC) on this topic, the inputs topic saying that the only internal sensors are battery voltage and device temperature. Any advice or information would be appreciated.
