Analog voltage input references
Are the pins labeled 0V all common to each other and are they or are they not connected to the main power return for the dash?
I would like to measure the voltage drop across a resistor. Like you might do with a hand held voltmeter. Neither end of the resistor is at ground potential so I need to know if the 0V pins on the dash are isolated from chassis ground. If they are all common to each other and another sensor pulls 0V to chassis ground then I might be stuck.
I don't have a dash here to play with so I don't have a way to figure it out by trial and error at this point. If some one could let me know that would be great.
Thanks,
Mark
Thanks,
Mark
