Simple SDL3 Fuel level sensor question
Re: Simple SDL3 Fuel level sensor question
Postby adrian on Wed Feb 21, 2018 10:12 am
The only issue I can see with that is that you have to get the length of the resistor and the wire exactly right.
If the wire from the splice to the pin is slightly longer or shorter than the resistor then there will some tension in the wiring and this can lead to failure with vibration, especially because the resistor leads are solid wire.
Postby BJ 991 on Wed Jun 06, 2018 3:42 pm
adrian wrote:The only issue I can see with that is that you have to get the length of the resistor and the wire exactly right.
A very belated thanks Adrian.
Got all this hooked up finally (it's an entire vehicle re-wire from scratch, so slow careful progress) and next step is to give it all power and start checking. Used your preferred method which worked a treat through a DT plug. Fingers crossed!
BJ 991
Return to ADL3, SDL3 and CDL3
