by JamieA on Wed Dec 21, 2011 9:05 am
When dividing up a CAN bus, there are 2 main things to consider, Load, and reliability.
I would consider this.
1) Reliability. If you have some items that are essential to keeping the car running, whilst having others that are less important, I would divide them us that way. So.....
CAN bus 0 M800, PDM, DBW4, CDI8
CAN bus 1 SLM, 4 X IRN4, BR2
this way, if any of the IRN4's have a problem and crash the bus, the car will continue to run. If you put the CDI8 on there, and it required the CAN bus to run, the car would stop. Reliability should be first consideration.
2) load. It is important if you have lots of traffic to share the bus loads. You dont want one unloaded CAN bus, and one that is empty. We have seen cars where one BUS is full, to the point of having dropouts whilst the other bus is not even used.
So, first priority is reliability, second is sharing the bus loads.
regards,
Jamie
