DASH with external lighting
Postby pnanassy on Fri Apr 08, 2011 4:22 pm
anyone used a non-backlit dash in dark conditions with external lighting?
Will that be usable?
Thank you,Peter
pnanassy
Re: DASH with external lighting
Postby JamieA on Wed Apr 13, 2011 4:14 pm
I have seen a race team use a normal dashboard globe on the steering column with a carbon fibre shroud buit around it to direct the light only over the display.
Should have worked ok, but didnt see it in use.
regards
jamie.
JamieA
Postby Martin on Thu Apr 14, 2011 4:17 am
Ive seen this before, and in a rally car of all things. I saw it when it was dark on a night stage, with white LED`s shining on its face. I really think spend the extra bucks and get yourself a backlit display.
Postby SprinterTRD on Thu Apr 14, 2011 10:51 am
The LEDS tend to have bright spots on the display and you get reflected light off the glass.
SprinterTRD
Return to ADL3, SDL3 and CDL3
