SDL3 Time, Chronograph, Fuel
Postby insomnia on Sat Jan 15, 2011 7:31 pm
I have a SDL3 and i want to mount it on my motorcycle. I need to display the fuel remaining in the tank in Liters,
the speed (from bike sensor on the output shaft from gearbox, Gear from Gear Sensor (easy) what's about final ratio for calibration?),Gear ,Odometer ,Time in hours and minutes (24h format) and the cherry on the cake the Chronograph.
The idea is to start the Chrono and stop it manual (momentary switch).is that possible? how to setup the display to see the lap time 10,20 or 30sec. after stop it? I want to learn more to realize this.
All idea and help are welcome to fix this Complete Setup
Thank you
insomnia
Re: SDL3 Time, Chronograph, Fuel
Postby OmarK on Tue Feb 01, 2011 7:57 am
You can display fuel remaining by setting up "Fuel Prediction" depending on your method of measuring fuel usage. Speed, odometer are setup under "Speed and Distance". If you are using a GPS there is GPS time which you can use and if you setup a button under "Devices" setup you can make a "user condition" to start/stop the running lap time channel. In the display setup you can use the overide feature to hold lap time on the display for as long as you need to. Make a start to your configuration file use Simulate and Monitor channels features to test your configuration file and then you can post it here on the forum to get further help from everybody. :)
OmarK
Postby insomnia on Tue Feb 08, 2011 9:02 pm
Thank you OmarK, this is a great help for me !
I try this this week and tell you more about this.
Francois
insomnia
Return to ADL3, SDL3 and CDL3
