Ethernet Connection
Ethernet Connection
Postby insomnia on Wed Jan 19, 2011 3:15 am
Can you explain me how work the Ethernet communication between SDL3 and PC?
About the cable,LAN or CROSSOVER ? Setup from the PC and the protocole ? Can i use an
UTC or not with the SDL3 ? Or only Ethernet ?
Thank for all advice
Francois
insomnia
Re: Ethernet Connection
Postby OmarK on Tue Jan 25, 2011 3:03 pm
To communicate with an SDL3 an ethernet connection is your only option you will not require a UTC. Most laptops have auto-crossover ethernet ports so a straight or crossover network cable should work.
1. Install ADL3/SDL3 Dash Manager on your PC.
2. Connect your dash to the PC via the Ethernet cable and turn on the ADL3/SDL3 power.
3. Open ADL3/SDL3 Dash Manager.
• On the Tools menu click Connection Settings and then click Add
• Click OK to choose IP (Ethernet). This is the only available connection type.
• Click Search*
• In the list with discovered devices, click the required Dash Logger and click Select
• Click OK to close the Connection Settings window
OmarK
Postby insomnia on Wed Jan 26, 2011 7:35 pm
Thank you OmarK,
I follow your advice,i'm waiting of the SDL3, coming this week.
Best Regards
Francois
insomnia
Return to ADL3, SDL3 and CDL3
