RPM input into SDL
RPM input into SDL
Postby Martin on Wed Mar 11, 2009 6:54 am
What would be the best way to get RPM into an SDL without splicing into wiring of a car?
This is for testing aplications so splicing into wiring is not a good option since it has to be done to many cars.
Could one coil some wire around the trigger wire? Would a coil areound the HT lead be dangerous?
And which would be the best output to wire it to?
THanks
M
Re: RPM input into SDL
Postby SprinterTRD on Wed Mar 11, 2009 8:12 am
You can get test probes for multimeters that clamp on to a wire and have a sharp needle which goes through the insulation.
SprinterTRD
Postby Martin on Wed Mar 11, 2009 3:59 pm
Thanks for the tip. Has nayone tried coiling wire around the trigger side?
Return to ADL3, SDL3 and CDL3
