Sports dash M1 can template
Postby Donovan CR6 on Fri Aug 07, 2020 7:53 pm
Hi
Is it possible to get a M1 template for a sport dash? Currently trying to connect to a M142. Cant even manually input it.
Donovan CR6
Re: Sports dash M1 can template
Postby adrian on Wed Aug 12, 2020 9:52 am
See below, you need to unzip the file and copy the templates to C:\Program Files (x86)\MoTeC\Dash\Sport Dash Manager 1.6\Comms Setup. You will then be able to select them in the communications setup in SDL Manager.
SDL M1 Templates.zip
(5.51 KiB) Downloaded 1371 times
Postby Donovan CR6 on Wed Aug 12, 2020 6:26 pm
Hi Adrian
When trying to load the config I get this error just after it finishes loading.
Any Ideas?
sdl error.jpg (196.44 KiB) Viewed 12511 times
Donovan CR6
Postby adrian on Wed Aug 19, 2020 3:03 pm
Can you send me the Dash configuration file that does this to support@motec.com.au
Return to ADL3, SDL3 and CDL3
Users browsing this forum: No registered users and 20 guests
