SDL Base model to Backlit
Postby BakZamGai on Fri Dec 19, 2008 5:36 pm
Hi there
Is it possible to upgrade a SDL Base model to one with a Backlit display?
How much would this upgrade cost?
What about the options already enabled in the current Base model?
Thanks!
BakZamGai
Re: SDL Base model to Backlit
Postby JamieA on Mon Dec 22, 2008 10:59 am
yes it can be done, but it is quite an expensive and time consuming task. We have to unsolder and remove the existing display completely, then solder on a new display.
Cost is about $1000aud, though I would have to check to find out exactly.
If you wanted to go ahead, send the dash to your local motec dealer, and they can organise it from there.
Regards
JamieA
Return to ADL3, SDL3 and CDL3
